This command is used to show the mvrp settings as follows. If the MVRP enabled port is a load shared port, a suffix ‘g‘ is displayed.
| mvrp | Multiple VLAN Registration Protocol. |
N/A.
Use this command to show the MVRP settings.
# show mvrp
MVRP enabled : Enabled
MVRP dynamic VLAN creation : Enabled
MVRP VLAN registration : Forbidden
MVRP default STP domain : s0
MVRP enabled ports : 9 *11 *13
Flags: (*) Active, (!) Administratively disabled.
(g) Load Sharing Port
(G) Multi-switch LAG Group port
This command was first available in ExtremeXOS 15.3.
MRVP VLAN registration output was added in 15.3.2.
Flag showing if the MVRP-enabled port is an This command is available on all Universal switches supported in this document. port added in ExtremeXOS 22.1
